발행일 : 03/10/2025
Importer Messages
obj<<AF Path(path1, path2, ...)
Description
Asset Framework path of the attribute to import. This can be a single path or multiple paths. The list of paths can be a JSL List, allowing the set of paths to be placed in a list variable.
obj<<Boundary Type("inside"|"outside"|"interpolated")
Description
Determines how values that occur near the start and end time boundaries are treated.
obj<<End Time(text)
Description
Optional end time of the series to import. Default value is "*" (now).
obj<<Filter(text)
Description
An optional filter expression using PI Server’s filter expression syntax.
obj<<Interval(text)
Description
Sampling interval in AFTimeSpan format. The default is "1h".
obj<<Intervals(n)
Description
Number of intervals to fetch. Default is 24.
obj<<Max Count(n)
Description
Sets the maximum number of values to retrieve. The default is 5000.
obj<<Retrieve Attribute Status(state=0|1)
Description
Specifies whether to retrieve attribute status, which is stored in an additional column. This column, named "<attribute-name> status", uses a Multiple Response property with Value Labels to display the status as a set of the values: "Good," "Questionable," "Substituted," and "Annotated." This option is disabled by default.
obj<<Series("raw"|"plot"|"interpolated")
Description
Specifies the time series type. The default value is "raw".
obj<<Stack(state=0|1)
Description
Stacks attributes with the same name into a single column, and creates stacking columns for the common elements in their paths.
obj<<Start Time(text)
Description
(Optional) Specifies the start time of the series to import. The default value is "*-1d" (24 hours ago).
obj<<Sync Time(text)
Description
(Optional) Specifies the synchronization time that sets the starting point from which interval boundaries are calculated.
obj<<Sync Time Boundary Type("inside"|"outside")
Description
Determines how values that occur near the start and end time boundaries are treated. The default value is "inside".
obj<<Timeout(n)
Description
Cancels the import operation after no data has been received for the given number of seconds. A negative value directs the operation to wait for the default amount.
obj<<UTC(state=0|1)
Description
(Optional) This flag indicates whether the start time and end time parameters are based on UTC. The default value is 0 (false).
