발행일 : 03/10/2025
Install R
Install R on the same computer as JMP. You can download R from the Comprehensive R Archive Network website:
https://cran.r-project.org
Note: For macOS Catalina and later versions, download the notarized and signed package.
Because JMP is a 64-bit application, you must install the corresponding 64-bit version of R. For the supported version of R, see the system requirements on the JMP website: https://www.jmp.com/system.
Override the Default R Install Location on Windows
Normally JMP determines the R_HOME environment variable internally if it is not defined in the Windows system registry:
computer\HKEY_LOCAL_MACHINE\SOFTWARE\R-code\R\InstallPath
You might have installed more than one version of R on your computer. To override the default R installation location, define the R_HOME environment variable using either of the two following methods:
1. Create the variable in your system environment variables using the Control Panel, select Start > Control Panel > System > Advanced system settings.
2. Click Environment Variables.
3. In the System variables pane, click New.
4. Type R_HOME for the Variable name.
5. Type the path to the R .exe file (for example, C:\Program Files\R\R-2.15.3).
6. Click OK and click OK again to close the System Properties window.
or
Create the variable using the JSL Set Environment Variable() function:
Set Environment Variable( "R_HOME", "C:\Program Files\R\R-2.15.3" );
Override the Default R Install Location on macOS
You might have installed more than one version of R on your computer. To use an older version, change the R_HOME environment variable to point to the R version that you want to use.
To specify the R_HOME location, follow these steps:
1. Open a terminal window.
2. Type the following code, where value is the location of R.
export R_HOME=value
3. Press Enter.
How JMP Finds R on Windows
JMP delays loading R until a JSL-based script requires access to it. When JMP needs to load R, it follows the standard steps for finding R on a Windows computer:
1. Look up the environment variable R_HOME.
If the variable exists, load R from the specified directory.
2. If the environment variable R_HOME does not exist, look up the InstallPath value in the Windows registry under the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\R-core\R
If the InstallPath value exists, load R from the specified directory.
3. If the InstallPath value does not exist, an error message states that R could not be found.
How JMP Finds R on macOS
JMP uses the value of the R_HOME environment variable if the variable exists. Otherwise, it looks in /Library/Frameworks/R.framework/Versions/Current/Resources for R.
Testing Your Setup
To test that your computer is able to run JSL-based scripts that use R, run the following JSL script:
R Init( );
R Submit( "
	x <- 1:5
	x
R Term( );
You should see the following output in the log:
[1] 1 2 3 4 5
