JSL Syntax Reference > JSL Messages > Interactive HTML Messages
발행일 : 03/10/2025
This section contains JSL messages for interactive HTML web reports.
Web Report Messages
webreport<<Publish(<Add Image(...)>, <Add Report(...)>, <Add Reports(...)>, <Public(Boolean)>, <Index(...), <User Name(...)>, <Password(...)|password function)>, <Prompt("IfNeeded"|"Always"|"Never")>, <URL(...)>, <Publish Data(Boolean)>, Replace(<id>, Prompt("IfNeeded"|"Always"|"Never"))>)
Description
Publishes the web report to the JMP server.
Returns
On success, the URL of the published report is returned.
Optional Arguments
Add Image
Inserts an image at the top of the index page. Valid formats are "png", "bmp", "jpeg", "jpg", "tiff", and "tif". Title and Description are optional. Title appears above the image. Description appears below the image. Use File(filepath) or just a quoted string. Here is an example:
webrpt << Add Image( File( "C:\Users\Public\JMP\Projects\WebJMP\atlas.jpg" ), Title( "Atlas" ), Description( "Holding up the world as always." ) );
Add Report
Adds a report to publish within the web report.
Public(Boolean)
Specifies whether the public has access to the report. By default, the report is private.
Index
The name of the index page for multiple reports. You can also specify the description.
User Name
Specifies the user name registered on the JMP server.
Password
Specifies the user’s password. You can also define a password function.
Prompt
Displays a window in which the user types the server URL, user name, and password.
URL
The location that you are publishing to.
Includes the data in the HTML. Reports contains static rather than interactive images. In a public report, you might not want to share the data.
Replace
Replaces the report. Get the URL from the address field in the browser where the page is displayed.
