발행일 : 03/10/2025
jmp Package Objects
The jmp Package exposes several JMP objects to Python. Use these objects to manage data tables, columns, column data types, and column modeling types.
jmp.DataTable
Description
Python Object wrapping a JMP data table.
jmp.DataTable.Column
Description
Python Object wrapping a JMP data table column.
jmp.DataType
Description
An enumeration of the Column’s data type. Values: Numeric, Character, RowState, or Expression.
jmp.ModelingType
Description
An enumeration of the column’s modeling type. Values: Continuous, MultipleResponse, Nominal, Ordinal, Text, TypeNone, or Vector.
