발행일 : 03/10/2025
Row State Functions
As Row State(i)
Description
Converts i into a row state value.
Returns
A row state from the i given.
Argument
i
an integer
Color Of(rowstate)
Description
Returns or sets the color index.
Returns
The color index of rowstate.
Argument
rowstate
a row state argument
Example
Set the color of the fifth row to red.
Color Of( Rowstate( 5) ) = 3
Color State(i)
Description
Returns a row state with the color index of i.
Returns
A row state.
Argument
i
index for a JMP color
Combine States(rowstate, rowstate, ...)
Description
Generates a row state combination from two or more row state arguments.
Returns
A single numeric representation of the combined row states.
Arguments
rowstate
Two or more row states.
Excluded(rowstate)
Description
Returns or sets an excluded index.
Returns
The excluded attribute, 0 or 1.
Argument
rowstate
One or more row states.
Excluded State(num)
Description
Returns a row state for exclusion from the num given.
Hidden(rowstate)
Description
Returns or sets the hidden index.
Hidden State(num)
Description
Returns a row state for hiding from the num given.
Hue State(num)
Description
Returns a hue state from the num given.
Labeled(rowstate)
Description
Returns or sets the labeled index.
Labeled State(num)
Description
Returns a labeled state from the num given.
Marker Of(rowstate)
Description
Returns or sets the marker index of a row state.
Marker State(num)
Description
Returns a marker state from the num given.
Row State(<dt,> <n>)
Description
Returns the row state changed from the initial condition of the active row or the nth row.
Arguments
dt
Optional positional argument: a reference to a data table. If this argument is not in the form of an assignment, then it is considered a data table expression.
n
The row number.
Example
The following example creates the data table references and then returns the row state of row 1 in Big Class.jmp:
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp" );
dt2 = Open( "$SAMPLE_DATA/San Francisco Crime.jmp" );
Row State( dt1, 1 );
Selected(rowstate)
Description
Returns or sets the selected index.
Selected State(num)
Description
Returns a selected state from the num given.
Shade State(num)
Description
The Shade State function assigns 5 shade levels to a color or hue.
Where(<dt>, clause)
Description
Filters and returns indices depending on the given clause. The clause can be a comparison function or a conditional statement. Columns, matrices, and lists can be mixed and matched within the same clause.
The indices returned by Where() are optimized for high performance on large lists, matrices, and columns.
Required Arguments
clause
A comparison function or conditional statement.
Optional Arguments
<dt>
Changes the current Data Table during the evaluation.
Examples
Names Default To Here( 1 );
dt << Select Rows( [2 4 6] ) << Exclude( 1 );
Where( Excluded() );
Where( !Excluded() );
