발행일 : 03/10/2025
Version Information
The JMP Version() inquiry function returns the JMP version as a string. You might use this function to determine the JMP version and then run a script compatible with that version.
JMP Version(); // returns "18.0.0" in JMP 18
JMP Version(); // returns " 9.0.0" in JMP 9
Notice that a leading blank is inserted before versions less than 10.0.0. This blank helps when comparing version numbers. Without the leading blank, 9.0.0 is interpreted as greater than 10.0.0.
