Scripting Guide > Data Tables > Work with Columns > Compress Selected Columns
발행일: 09/10/2026
To minimize the size of a large data table, use the Compress Selected Columns message. Each column is compressed into the most compact form.
dt << Compress Selected Columns( {column name, column name} );
For example, compress the age, sex, height, and weight columns in Big Class.jmp:
{:age, :sex, :height, :weight}
For more information about this feature, see “Compress Selected Columns in Data Tables” in Using JMP.
