Scripting Guide > Programming Methods > File and Directory Operations
발행일: 09/10/2026
Pick Directory() and Pick File() enable the user to select a file or directory when the JSL script is run. To get a list of files in a directory, use Files In Directory().
• Select a Directory or File
• Get a List of File Names
• Connect to a Network Directory
