발행일: 09/10/2026
JMPEX R Functions
jmpex.R.R( <'BACKEND'> )
Description
Creates the R class object. The optional BACKEND parameter specifies the backend R support. Currently only rpy2 is supported, and is the default if not specified.
jmpex.R.R.get( 'R_variable' )
Description
Gets a variable from the R environment.
Returns
The value of the variable to Python using r2obj(). Returns an R DataFrame as a pandas.DataFrame.
Example
import jmp
from jmpex.R import R
dt = jmp.open(jmp.SAMPLE_DATA + 'Big Class.jmp')
jr = R()
a = jr.set( dt['age'], 'r_age' ) # as_name required from Python
print(a.__class__)
print(a)
ra = jr.get('r_age')
print( ra.__class__ )
print( ra )
Note that on the Python side, jmpex.R.R.set() requires setting the ‘as_name’ parameter to name the variable in R.
jmpex.R.R.is_connected()
Description
Returns whether the R subsystem has been initialized. This is a static function that is available regardless of whether an R() instance object exists.
Returns
A Python True or False.
Example
import jmp
print(f'\nR initialized 1: {R.is_connected()}\n')
jr = R()
print(f'\nR initialized 2: {R.is_connected()}')
jmpex.R.R.obj2r( PyObj )
Description
Creates an R object from a Python object, where an appropriate conversion exists.
Returns
The created object or None.
Example
import jmp
jr = R()
d = { "canine": ["poodle", "dalmation", "wolf"],
      "ages": [ 1, 3, 5],
      "vet bill": [200.0, 300.57, 2000.99] }
r_obj = jr.obj2r( d )
p_obj = jr.r2obj( r_obj )
print(r_obj.__class__)
print(r_obj)
print(p_obj.__class__)
print(p_obj)
jmpex.R.R.r_version()
Description
Returns the version of R. Also prints to the log the rpy2 version, and the rpy2 package path.
Example
import jmp
jr = R()
print(f'R Version: {jr.r_version()}')
jmpex.R.R.r2obj( rpy2_object )
Description
Creates a Python object from an R or rpy2 object where an appropriate conversion exists.
Returns
Example
import jmp
jr = R()
      "ages": [ 1, 3, 5],
print(r_obj)
print(p_obj)
jmpex.R.R.set( Python_variable, 'as_R_name' )
Description
Sets a Python variable in the R environment named by the required ‘as_R_name’ parameter. The R object is created using obj2r().
Example
import jmp
jr = R()
a = jr.set( dt['age'], 'rage' ) # as_name required from Python
print(a.__class__)
print(a)
ra = jr.get('rage')
print( ra )
jmpex.R.R.submit( 'R_script' )
Description
Submits R program code for evaluation.
Returns
A Python object, if possible.
Example
import jmp
jr = R()
# R DataFrame can be jmp.DataTable, pandas.DataFrame, etc.
d = jr.set( dt , 'Big.Class' ) # becomes 'Big.Class'
df = jr.submit('Big.Class')    # see: JSL R Send File(); R Submit();
print(f'DataFrame:\n{df}')
print(d.__class__)
print(d)
bc = jr.get('Big.Class')
print( bc.__class__ )
print( bc )
jmpex.R.R.submit_file( 'path to R source file' )
Description
Submits an R script file for evaluation.
Returns
Example
import jmp
jr = R()
# jr.submit_file(''' Path to R source file ''')
