발행일: 09/10/2026
Select Fragmented Text
To select text that is not contiguous in a script, press Ctrl on Windows or Command on Apple macOS and drag your cursor over the text. Continue this action for any other text that you want to select. You can then copy and paste your selection into a new script or you can run the selected text. Text will be pasted or run in the order it was selected.
