Multivariate Methods > Discriminant Analysis > Discriminant Analysis Options
Publication date: 07/30/2020
The Discriminant Analysis red triangle menu contains the following options:
Stepwise Variable Selection
Selects or deselects the Stepwise control panel. See Stepwise Variable Selection.
Discriminant Method
Selects the discriminant method. See Discriminant Methods.
Discriminant Scores
Shows or hides the Discriminant Scores portion of the report.
Score Options
Provides several options connected with the scoring of the observations. In particular, you can save the scoring formulas. See Score Options.
Canonical Plot
Shows or hides the Canonical Plot. See Canonical Plot and Canonical Structure.
Canonical Options
Provides options that affect the Canonical Plot. See Canonical Options.
Canonical 3D Plot
Shows a three-dimensional canonical plot. This option is available only when there are four or more levels of the categorical X. See Example of a Canonical 3D Plot.
Specify Priors
Enables you to specify prior probabilities for each level of the X variable. See Specify Priors.
Consider New Levels
Used when you have some points that might not fit any known group, but instead might be from an unscored new group. See Consider New Levels.
Show Within Covariances
Shows or hides these reports:
A Covariance Matrices report that gives the pooled-within covariance and correlation matrices.
For the Quadratic and Regularized methods, a Correlations for Each Group report that shows the within-group correlation matrices.
For each group, the log of the determinant of the within-group covariance matrix is also shown.
For the Quadratic discriminant method, adds a Group Covariances outline to the Covariance Matrices report that shows the within-group covariance matrices.
Show Within Covariances is not available for the Wide Linear discriminant method.
Show Group Means
Shows or hides a Group Means report that provides the means of each covariate. Means for each level of the X variable and overall means appear.
Save Discrim Matrices
Saves a script called Discrim Results to the data table. The script is a list of the following objects for use in JSL:
a list of the covariates (Ys)
the categorical variable X
a list of the levels of X
a matrix of the means of the covariates by the levels of X
the pooled-within covariance matrix
Save Discrim Matrices is not available for the Wide Linear discriminant method. See Save Discrim Matrices.
Scatterplot Matrix
Opens a separate window containing a Scatterplot Matrix report that shows a matrix with a scatterplot for each pair of covariates. The option invokes the Scatterplot Matrix platform with shaded density ellipses for each group. The scatterplots include all observations in the data table, even if validation is used. See Scatterplot Matrix.
Not available for the Wide Linear discriminant method.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
