发布日期: 04/13/2021
Connect to the CAS Server
You can show the login window and prompt the user to provide the URL for the CAS server and their login information.
CAS Connect( Prompt( "Never"|"Always"|"IfNeeded" ) );
To add the login details to the script, follow this example:
CAS Connect(URL(URL), Username(username), Password(password);
Information about the CAS server appears in the log after the user logs in.
