JSL Syntax Reference > JSL Messages > JMP Applications
发布日期: 04/13/2021
JMP Applications
The JMP Application Builder and JMP Dashboard Builder use the same infrastructure to design and execute applications and dashboards. Because a dashboard is a special form of an application, this section uses the term application to describe how both dashboard and application objects use scripting.
See Creating Applications in the Scripting Guide for more information about Application Builder.
See the Scripting Index in the JMP Help menu for examples.
