发布日期: 04/13/2021
Load and Save Text Files
The Load Text File() and Save Text File() commands allow manipulation of text files from JSL. Note that the paths in the following code are strings.
text = Load Text File( "path" );
Save Text File( "path", text );
You can load a text file from a Web site:
Load Text File( "URL", <blob> );
The URL is a quoted string that contains the URL for the text file. The text file is returned as a string. If you add the optional named argument blob, a blob is returned instead.
