发布日期: 04/13/2021
Save the Log
You can also save logs as text files, which can be viewed with any text editor. Double-clicking a log text file opens it in your default text editor, not in JMP.
1. Make the log window active (click the Log window to make it the front-most window).
2. From the File menu, select Save or Save As.
3. Specify a filename, including the extension .txt on Windows. On macOS, you cannot save a log as a .txt file. .jsl is appended to the file name.
4. Click Save.
