发布日期: 04/13/2021
Select Fragmented Text
To select text that is not contiguous, hold down the Ctrl key on Windows or Command key on macOS and drag your cursor over the text. Continue this action for any other text that you want to select. You can then copy and paste your selection into a new script or you can run the selected text. Text will be pasted or run in the order it was selected.
