发布日期: 11/15/2021
Control Chart Script-Only Messages
When you launch the Control Chart platform via JSL, you can use the following arguments that are available only in JSL:
Chart Col( column, chart_type( Avg( number ), UCL( number ), LCL( number ) )
Chart Type( string )
Get Limits( string )
Get Targets( string ) //Multivariate Control Charts
Use Excluded Points on MR
The following messages for a Control Chart object are available only in JSL:
control_chart_object << Point Marker( string ); //CUSUM charts
control_chart_object << Save Limits( string );
