发布日期: 11/15/2021
Model Screening Script-Only Messages
When you launch the Model Screening platform via JSL, you can use the following arguments that are available only in JSL:
Model NParm Limit( number )
Set Probability Threshold( number )
SVM NRow Limit( number )
The following message for a Model Screening object is available only in JSL:
model_screening_object << Select Fit( ... );
