发布日期: 11/15/2021
Partition Script-Only Messages
When you launch the Partition platform via JSL, you can use the following arguments that are available only in JSL:
Initial Splits( ... )
Missing Value Order( Low( list of numeric columns ), High( list of numeric columns ) )
Multithreading( 0|1 )
Set Random Seed( number )
The following messages for a Partition object that return the requested item from the fitted model are available only in JSL:
partition_object << Get Average Absolute Error Test;
partition_object << Get Average Absolute Error Training;
partition_object << Get Average Absolute Error Validation;
partition_object << Get Average Log Error Test;
partition_object << Get Average Log Error Training;
partition_object << Get Average Log Error Validation;
partition_object << Get Confusion Matrix Test;
partition_object << Get Confusion Matrix Training;
partition_object << Get Confusion Matrix Validation;
partition_object << Get Confusion Rates Test;
partition_object << Get Confusion Rates Training;
partition_object << Get Confusion Rates Validation;
partition_object << Get Difference Formula;
partition_object << Get Gen RSquare Test;
partition_object << Get Gen RSquare Training;
partition_object << Get Gen RSquare Validation;
partition_object << Get Measures;
partition_object << Get Microseconds;
partition_object << Get Misclassification Rate Test;
partition_object << Get Misclassification Rate Training;
partition_object << Get Misclassification Rate Validation;
partition_object << Get MM SAS Data Step;
partition_object << Get MM Tolerant SAS Data Step;
partition_object << Get Prediction Formula;
partition_object << Get RMS Error Test;
partition_object << Get RMS Error Training;
partition_object << Get RMS Error Validation;
partition_object << Get ROC Area Test;
partition_object << Get ROC Area Training;
partition_object << Get ROC Area Validation;
partition_object << Get RSquare Test;
partition_object << Get RSquare Training;
partition_object << Get RSquare Validation;
partition_object << Get SAS Data Step;
partition_object << Get Seconds;
partition_object << Get Tolerant Prediction Formula;
partition_object << Get Tolerant SAS Data Step;
