发布日期: 11/15/2021
Process Screening Script-Only Messages
When you launch the Process Screening platform via JSL, you can use the following arguments that are available only in JSL:
Drift Alpha( number )
Make Detailed Shift Data( 0|1 )
Ppk Capability Boundary( number )
Remove( column )
Stability Index Boundary( number )
Stability Ratio Boundary( number )
The following messages for a Process Screening object are available only in JSL:
process_screening_object << RowStates;
process_screening_object << Select All;
