发布日期: 03/04/2025
Character Pattern Functions
See Pattern Matching in the Scripting Guide for more detailed information about constructing and using pattern matching expressions.
Pat Abort()
Description
Constructs a quoted pattern that immediately stops the pattern match. The matcher does not back up and retry any alternatives. Conditional assignments are not made. Immediate assignments that were already made are kept.
Returns
0 when a match is stopped.
Argument
none
Pat Altern(pattern1, <pattern2, ...>)
Description
Constructs a quoted pattern that matches any one of the pattern arguments.
Returns
A quoted pattern.
Argument
One or more patterns.
Pat Any(string)
Description
Constructs a quoted pattern that matches a single character in the argument.
Returns
A quoted pattern.
Argument
pattern
A quoted string.
See Also
Regular Expressions in the Scripting Guide
Pat Arb()
Description
Constructs a quoted pattern that matches an arbitrary quoted string. It initially matches the null quoted string. It then matches one additional character each time the pattern matcher backs into it.
Returns
A quoted pattern.
Argument
none
Example
p = "the beginning" + Pat Arb() >? stuffInTheMiddle + "the end";
Pat Match( "in the beginning of the story, and not near the end, there are three bears", p );
Show( stuffInTheMiddle );
stuffInTheMiddle = " of the story, and not near "
See Also
Pat Arb No(pattern)
Description
Constructs a quoted pattern that matches zero or more copies of pattern.
Returns
A quoted pattern.
Argument
pattern
A quoted pattern to match against.
Example
adjectives = "large" | "medium" | "small" | "warm" | "cold" | "hot" | "sweet";
rc = Pat Match( "I would like a medium hot, sweet tea please",
               Pat Arbno( adjectives | Pat Any(", ") ) >> adj +
               ("tea" | "coffee" | "milk") );
Show( rc, adj );
rc = 1;
adj = " medium hot, sweet ";
Pat At(varName)
Description
Constructs a quoted pattern that matches the null quoted string and stores the current position in the source string into the specified JSL variable (varName). The assignment is immediate, and the variable can be used with expr() to affect the remainder of the match.
Returns
A quoted pattern.
Argument
varName
The name of a variable to store the result in.
Example
p = ":" + Pat At( listStart ) + Expr(
	If( listStart == 1,
		Pat Immediate( Pat Len( 3 ), early ),
		Pat Immediate( Pat Len( 2 ), late )
early = "";
late = "";
Pat Match( ":123456789", p );
Show( early, late );
early = "";
late = "";
Pat Match( "   :123456789", p );
First this is produced:
early = "123"
late = ""
and later this:
early = ""
late = "12"
Pat Break(string)
Description
Constructs a quoted pattern that matches zero or more characters that are not in its argument; it stops or breaks on a character in its argument. It fails if a character in its argument is not found (in particular, it fails to match if it finds the end of the quoted source string without finding a break character).
Returns
A quoted pattern.
Argument
string
A quoted string.
Pat Concat(pattern1, pattern2 <pattern3, ...>)
Pattern1 + Pattern2 + ...
Description
Constructs a quoted pattern that matches each pattern argument in turn.
Returns
A quoted pattern.
Argument
Two or more quoted patterns.
Pat Conditional(pattern, varName)
Description
Saves the result of the quoted pattern match, if it succeeds, to a variable named as the second argument (varName) after the match is finished.
Returns
A quoted pattern.
Arguments
pattern
varName
Example
type = "undefined";
rc = Pat Match(
	"green apples",
	Pat Conditional( "red" | "green", type ) + " apples"
Show( rc, type );
rc = 1;
type = "green";
Pat Fail()
Description
Constructs a quoted pattern that fails whenever the matcher attempts to move forward through it. The matcher backs up and tries different alternatives. If and when there are no alternatives left, the match fails and Pat Match returns 0.
Returns
0 when a match fails.
Argument
none
Pat Fence()
Description
Constructs a pattern that succeeds and matches the quoted null string when the matcher moves forward through it, but fails when the matcher tries to back up through it. It is a one-way trap door that can be used to optimize some matches.
Returns
1 when the match succeeds, 0 otherwise.
Argument
none
Pat Immediate(pattern, varName)
Description
Saves the result of the pattern match to a variable named as the second argument (varName) immediately.
Returns
A quoted pattern.
Arguments
pattern
varName
Example
type = "undefined";
rc = Pat Match(
	"green apples",
	("red" | "green") >> type + " pears"
Show( rc, type );
rc = 0
type = "green"
Even though the match failed, the immediate assignment was made.
Pat Len(int)
Description
Constructs a quoted pattern that matches n characters.
Returns
A quoted pattern.
Argument
int
An integer that specifies the number of characters.
See Also
Parse Strings in Fixed Fields in the Scripting Guide
Pat Look Ahead(pattern, Boolean)
Description
A zero-width pattern match after the current position.
Arguments
pattern
The quoted pattern.
Boolean
0 (the default) indicates a match. 1 indicates a negative match or non-match.
Pat Look Behind(pattern, Boolean)
Description
A zero-width quoted pattern match before the current position.
Arguments
pattern
The quoted pattern.
Boolean
Pat Match(source text, pattern, <replacement string>, <"NULL">, <"ANCHOR">, <"MATCHCASE">, <"FULLSCAN">)
Description
Pat Match executes the quoted pattern against the source text. The pattern must be constructed first, either inline or by assigning it to a JSL variable elsewhere.
Returns
1 if the pattern is found, 0 otherwise.
Required Arguments
source text
A quoted string or quoted string variable that contains the text to be searched.
pattern
A quoted pattern or pattern variable that contains the text to be searched for.
Optional Arguments
replacement string
A quoted string that defines text to replace the pattern in the source text.
"NULL"
A placeholder for the third argument if ANCHOR, MATCHCASE, or FULLSCAN are necessary and there is no replacement text.
"ANCHOR"
Starts the pattern match at the beginning of the quoted string. The following match fails because the pattern, “cream”, is not found at the beginning of the string:
Pat Match( "coffee with cream and sugar", "cream", NULL, ANCHOR );
"MATCHCASE"
Optional command to consider capitalization in the match. By default, Pat Match() is case insensitive.
"FULLSCAN"
Optional command to force Pat Match to try all alternatives, which uses more memory as the match expands. By default, Pat Match() does not use FULLSCAN, and makes some assumptions that allow the recursion to stop and the match to succeed.
See Also
Pat Not Any(string)
Description
Constructs a pattern that matches a single character that is not in the argument.
Returns
A quoted pattern.
Argument
string
A quoted string.
See Also
Troubleshoot Patterns in the Scripting Guide
Pat Pos(int)
Description
Constructs patterns that match the quoted null string if the current position is int from the left end of the string, and fail otherwise.
Returns
A quoted pattern.
Argument
int
An integer that specifies the position in a quoted string.
See Also
Pat R Pos(int)
Description
Constructs patterns that match the quoted null string if the current position is int from the right end of the string, and fails otherwise.
Returns
A quoted pattern.
Argument
int
See Also
Pat R Tab(int)
Description
Constructs a quoted pattern that matches up to position n from the end of the quoted string. It can match 0 or more characters. It fails if it would have to move backwards or beyond the end of the string.
Returns
A quoted pattern.
Argument
int
An integer that specifies a position in a quoted string.
See Also
Pat Regex(string)
Description
Constructs a quoted pattern that matches the regular expression in the quoted string argument.
Returns
A quoted pattern.
Argument
string
A quoted string.
See Also
Patterns and Case Matching in the Scripting Guide
Pat Rem()
Description
Constructs a quoted pattern that matches the remainder of the quoted string. It is equivalent to Pat R Tab(0).
Returns
A quoted pattern.
Argument
none
See Also
Pat Repeat(pattern, minimum, maximum, <"GREEDY"|"RELUCTANT">)
Description
Matches the quoted pattern between minimum and maximum times.
Returns
A quoted pattern.
Required Arguments
pattern
A pattern to match against.
minimum
An integer that must be smaller than maximum.
maximum
An integer that must be greater than minimum.
Optional Argument
If GREEDY is specified, it tries the maximum first and works back to the minimum. If RELUCTANT is specified, it tries the minimum first and works up to the maximum.
Notes
– Pat Arbno(p) is the same as Pat Repeat(p, 0, infinity, RELUCTANT)
– Pat Repeat(p) is the same as Pat Repeat(p, 1, infinity, GREEDY)
– Pat Repeat(p, n) is the same as Pat Repeat(p, n, infinity, GREEDY)
– Pat Repeat(p, n, m) is the same as Pat Repeat(p, n, m, GREEDY)
See Also
Pat Span(string)
Description
Constructs a pattern that matches one or more (not zero) occurrences of characters in its argument. It is greedy; it always matches the longest possible quoted string. It fails rather than matching zero characters.
Returns
A quoted pattern.
Argument
string
A quoted string.
See Also
Pat String(string)
Description
Constructs a pattern that matches its quoted string argument.
Returns
A quoted pattern.
Argument
string
A quoted string.
Pat Succeed()
Description
Constructs a pattern that always succeeds, even when the matcher backs into it. It matches the quoted null string.
Returns
1 when the match succeeds.
Argument
none
Pat Tab(int)
Description
Constructs a pattern that matches forward to position int in the quoted source string. It can match 0 or more characters. It fails if it would have to move backwards or beyond the end of the string.
Returns
A pattern.
Argument
int
See Also
Pat Test(expr)
Description
Constructs a pattern that succeeds and matches the quoted null string if expr is not zero and fails otherwise.
Returns
A quoted pattern.
Argument
expr
An expression.
Notes
Usually the argument is wrapped with expr() because the test needs to be made on the current value of variables set by Pat Immediate, Pat Conditional, and Pat At. Without expr, the test is based on values that were known when the pattern was constructed, which means the test always succeeds or always fails at pattern execution time, which is probably not what you want.
Example
nCats = 0;
whichCat = 3;
string = "catch a catnapping cat in a catsup factory";
rc = Pat Match(
	string,
	"cat" + Pat Test(
		Expr(
			nCats = nCats + 1;
			nCats == whichCat;
	"dog"
Show( rc, string, nCats );
rc = 1
string = "catch a catnapping dog in a catsup factory"
nCats = 3
Regex Match(source, pattern, <replacement string>|<"MATCHCASE">, <"NULL">)
Description
Executes the pattern match in quoted pattern against the quoted source string.
Returns
A pattern.
Required Arguments
source
A quoted string.
pattern
A quoted pattern.
Optional Arguments
replacement string
The quoted string that specifies the text to replace the source with.
"MATCHCASE"
The search is case insensitive unless you specify MATCHCASE.
"NULL"
Indicates that the expression contains MATCHCASE but you don’t want to specify a replacement.
Examples
Regex Match(
	"person=Fred id=77 friend= favorite=tea", // source
	"(\w+)=(\S*) (\w+)=(\S*) (\w+)=(\S*) (\w+)=(\S*)" // pattern
{"person=Fred id=77 friend= favorite=tea", "person", "Fred", "id", "77", "friend", "", "favorite", "tea"}
// case-insensitive, no replacement
Regex Match( "beliEve", "([aeiou])(.*?)(\1)" );
{"eliE", "e", "li", "E"}
// case-sensitive, no replacement
Regex Match( "beliEve", "([aeiou])(.*?)(\1)", NULL, MATCHCASE );
{"eliEve", "e", "liEv", "e"}
See Also
Regex Match Function in the Scripting Guide
