JSL Syntax Reference > JSL Messages > Data Connector Messages
发布日期: 03/04/2025
This section contains JSL messages for configurable data connectors.
Data Connector Metadata Messages
metadata<<Get Description()
Gets the data connector description.
metadata<<Get Driver()
Gets the data connector driver, if there is one.
metadata<<Get Name()
Gets the data connector name.
metadata<<Get Path()
Gets the data connector path.
metadata<<Get Type()
Gets the data connector type.
metadata<<Set Description(description)
Sets the data connector description.
metadata<<Set Name(name)
Sets the data connector name.
Data Connector Registry Messages
dc<<Get(name)
Retrieves a data connector from the registry.
dc<<Get Available()
Retrieves a list of available data connectors in the registry.
dc<<Get Metadata(name)
Gets a data connector’s metadata from the registry.
dc<<Register(Path(path), <Name(name)>, <Description(description)>)
Description
Adds a data connector to the registry.
Required Arguments
path
The path to register the data connector to.
name
The name of the data connector.
Optional Arguments
description
The description of the data connector.
Example
Names Default To Here( 1 );
Data Connector Registry() << Register(
	Path( "$DOCUMENTS/my connector.jmpdc" ),
	Name( "My Data Connector" )
dc<<Unregister(name)
Removes a data connector from the registry.
