Scripting Guide
发布日期: 03/04/2025
Scripting Guide
Introduction to Writing JSL Scripts
Welcome to the JMP Scripting Language
The JMP Scripting Language, or JSL, lets you write scripts to re-create results in JMP. Power users often develop scripts to extend JMP’s functionality and automate a regularly scheduled analysis in production settings. If you do not want to learn JSL, JMP can write the scripts for you.
JSL is used to perform many actions:
• implements column formulas
• launches platforms
• interactively modifies platforms
• creates graphics
Contents
What JSL Can Do for You
Help with Learning JSL
The Scripting Guide
The Scripting Index
Let JMP Teach You JSL
JSL Terminology
Basic JSL Syntax
Scripting Guide Conventions
