发布日期: 09/15/2026
Control Chart Builder Scripts
You can use JSL to create specific control charts, customize tests, run alarm scripts, and more.
Types of Control Charts
This section describes how to create different types of control charts using JSL scripting. For a general overview of control charts, see “Control Chart Builder” in Quality and Process Methods. The basic template for scripting a chart in Control Chart Builder is as follows:
Control Chart Builder(
	Class("Shewhart Variables"|"Shewhart Attribute"|"Short Run"|"Rare Event"),
	Variables( Y( column ), <Subgroup( column )>, <Phase( column )>, <Part( column )>, <n Trials( column )>,
	<Chart(
		Position( number ),
		Points( Statistic( "statistic" ), <points options> ),
		Limits( Sigma( "sigma" ), <limits options> ),
You can create different types of control charts by specifying different combinations of the Class, Variable, Statistic, and Sigma options.
The remainder of this section provides scripting templates for the different types of control charts.
Create an IMR chart by adding a continuous Y variable.
dt << Control Chart Builder( Variables( Y( continuous column ) ) );
Create an XBar/S chart by adding a Y variable and either adding a subgroup variable or defining a subgroup size. The Statistic for the dispersion chart must be set to Standard Deviation and the Sigma for the location chart must be set to Standard Deviation.
// Subgroup variable
	Variables( Y( column ), Subgroup( column ) ),
	Chart( Position( 1 ), Limits( Sigma( "Standard Deviation" ) ) ),
	Chart( Position( 2 ),
		Points( Statistic( "Standard Deviation" ) ),
// Define subgroup size
	Variables( Y( column ) ),
	Set Subgroup Size( number ),
Create an XBar/R chart by adding a Y variable and either adding a subgroup variable or defining a subgroup size.
	Set Subgroup Size ( number )
Create a Short Run Difference chart by setting the Class to Short Run and adding a Part variable. The Statistic values for the location chart and dispersion chart are automatically set to Centered and Moving Range Centered, respectively.
	Class( "Short Run" ),
	Variables( Y( column ), Part( column ) )
Create a Short Run Standardized chart by setting the Class to Short Run and adding a Part variable. The Statistic for the location chart type must be set to Standardized and the Statistic for the dispersion chart must be set to Moving Range Standardized.
	Variables( Y( column ), Part( column ) ),
	Chart( Position( 1 ), Points( Statistic( "Standardized" ) ) ),
	Chart( Position( 2 ), Points( Statistic( "Moving Range Standardized" ) ) )
Create a Run chart by adding a Y variable, turning off the limits, and removing the dispersion chart.
	Show Two Shewhart Charts( 0 ),
	Chart( Limits( Show Lower Limit( 0 ), Show Upper Limit( 0 ) ) )
Create a P chart by adding a Y variable, setting the Class to Shewhart Attribute, setting the Statistic to Proportion, and setting the Sigma to Binomial.
	Class( "Shewhart Attribute" ),
	Variables( Y( column ), <Subgroup( column )>, <Phase( column )> ),
	Chart(
		Points( Statistic( "Proportion" ) ),
		Limits( Sigma( "Binomial" ) )
Create an NP chart by adding a Y variable, setting the Class to Shewhart Attribute, setting the Statistic to Count, and setting the Sigma to Binomial.
	Chart(
		Points( Statistic( "Count" ) ),
Create a C chart by adding a Y variable, setting the Class to Shewhart Attribute, setting the Statistic to Count, and setting the Sigma to Poisson.
	Chart(
		Limits( Sigma( "Poisson" ) )
Create a U chart by adding a Y variable, setting the Class to Shewhart Attribute, setting the Statistic to Proportion, and setting the Sigma to Poisson.
	Chart(
Create a Laney P′ chart by adding a Y variable, setting the Class to Shewhart Attribute, setting the Statistic to Proportion, and setting the Sigma to Laney P Prime.
	Variables( Y( column ), <Subgroup( column )> ),
	Chart(
		Limits( Sigma( "Laney P Prime" ) )
Create a Laney U′ chart by adding a Y variable, setting the Class to Shewhart Attribute, setting the Statistic to Proportion, and setting the Sigma to Laney U Prime.
	Chart(
		Limits( Sigma( "Laney U Prime" ) )
Create a Levey-Jennings chart by adding a Y variable, removing the dispersion chart, and setting the Sigma to Levey Jennings. The Statistic is automatically set to Individual.
	Chart(
		Limits( Sigma( "Levey Jennings" ) )
Create an IMR on Means chart by adding a Y variable and either adding a subgroup variable or defining a subgroup size. The Statistic for the dispersion chart must be set to Moving Range on Means and the Sigma on both charts must be set to Moving Range.
	Chart( Position( 1 ), Limits( Sigma( "Moving Range" ) ) ),
		Points( Statistic( "Moving Range on Means" ) ),
Create an IMR on Group Standard Deviation chart by adding a Y variable and either adding a subgroup variable or defining a subgroup size. The Statistic for the location chart must be set to Standard Deviation, the Statistic on the dispersion chart must be set to Moving Range on Std Dev, and the Sigma on both charts must be set to Moving Range.
	Chart(
		Position( 1 ),
	Chart(
		Position( 2 ),
		Points( Statistic( "Moving Range on Std Dev" ) ),
	Chart(
		Position( 1 ),
	Chart(
		Position( 2 ),
Create a Median Moving Range chart by adding a Y variable and setting the Sigma to Median Moving Range in both the location and dispersion charts.
	Chart( Position( 1 ), Limits( Sigma( "Median Moving Range" ) ) ),
	Chart( Position( 2 ), Limits( Sigma( "Median Moving Range" ) ) )
Create a Median Moving Range on Group Means chart by adding a Y variable and either adding a subgroup variable or defining a subgroup size. The Statistic for the dispersion chart must be set to Moving Range on Means and the Sigma on both charts must be set to Median Moving Range.
	Chart(
		Position( 1 ),
	Chart(
		Position( 2 ),
	Chart(
		Position( 1 ),
	Chart(
		Position( 2 ),
Create a Median Moving Range on Group Standard Deviations chart by adding a Y variable and either adding a subgroup variable or defining a subgroup size. The Statistic for the location chart must be set to Standard Deviation, the Statistic for the dispersion chart must be set to Moving Range on Std Dev, and the Sigma on both charts must be set to Median Moving Range.
	Chart(
		Position( 1 ),
	Chart(
		Position( 2 ),
	Chart(
		Position( 1 ),
	Chart(
		Position( 2 ),
Create a Three Way chart by adding an additional dispersion chart after adding a Y variable and adding either a Subgroup variable or defining a subgroup size.
	Chart(
		Position( 1 ),
		Points( Statistic( "statistic" ) ),
		Limits( Sigma( "sigma" ) ),
	Chart(
		Position( 2),
	Chart(
		Position( 3 ),
	Set Subgroup Size ( number ),
	Chart(
		Position( 1 ),
	Chart(
		Position( 2),
	Chart(
		Position( 3 ),
Create a G chart by setting the Class to Rare Event and adding a nonnegative discrete Y variable. The Sigma is automatically set to Negative Binomial.
	Class( "Rare Event" ),
	Variables( Y( nonnegative discrete column ), <Subgroup( column )> ),
	Chart(
Create a T chart by setting the Class to Rare Event and adding a nonnegative discrete Y variable. The Sigma must be set to Weibull.
	Chart(
		Limits( Sigma( "Weibull" ) )
Reference Lines in Control Chart Builder
If you add a custom reference line to a Control Chart Builder chart through JSL, the reference line label must be something other than “LSL”, “USL”, or “AVG”. These names are keywords used by the Control Chart Builder platform.
The following example creates custom reference lines with unique labels.
obj = dt << Control Chart Builder(
	Variables( Y( :height ) ),
	SendToReport(
		Dispatch(
			"height",
			ScaleBox,
			{Add Ref Line( 70, "Solid", "Black", "Upper Limit", 1 ),
			Add Ref Line( 55, "Solid", "Black", "Lower Limit", 1 )}
Customize Tests in Control Chart Builder
You can design custom tests and select or deselect multiple tests at once using the Customize Tests function. You specify the description, desired number, and label. This option is available only for Variables and Attribute chart types.
The following example creates a custom test called Test 1 and turns it on.
dt = Open( "$SAMPLE_DATA/Quality Control/Diameter.jmp" );
	Variables( Subgroup( :DAY ), Y( :DIAMETER ) ),
	Customize Tests( Test 1( 2, "1" ) ), // test number, n, label
	Chart( Position( 1 ), Warnings( Test 1( 1 ) ) ), // turn Test 1 on
	Chart( Position( 2 ) )
Run Alarm Scripts
An alarm script alerts you when the data fail one or more tests. As an Alarm Script is invoked, the following variables are available, both in the issued script and in subsequent JSL scripts:
qc_col is the name of the column
qc_AlarmReportCol is name of the column
qc_byLevel is the level of the By variable
qc_categoricalX is an indicator that the horizontal axis is categorical
qc_test is the test that failed
qc_sample is the sample number
qc_sampleWithinPhase is the sample number within a phase
qc_phase is the label of the phase during which the failure occurred
qc_rows is a string of the numbers of the rows that are associated with the warning
qc_nRows is the total number of rows in the data table
qc_firstRow is the first row in the sample
qc_lastRow is the last row in the sample
qc_nSubgroups is the total number of subgroups
qc_chart is the chart where the failure occurred
qc_ChartName is the name of the chart where the failure occurred
qc_tableName is the name of the data table where the failure occurred
qc_sampleName is the name of the sample during which the failure occurred
qc_phaseName is the name of the phase during which the failure occurred
qc_chartTypeNumber is an internal mapping to the chart name
qc_value is the numeric value of the specific point that is associated with the warning
qc_statPlotted is the name of the statistic that is plotted
qc_where is a string of the numbers of the rows that are excluded
qc_dataHidden is an indicator that a warning is associated with hidden data
qc_dataExcluded is an indicator that a warning is associated with excluded data
qc_ProportionFailures is the proportion of samples that are out of control
qc_SumFailures is the total number of samples that are out of control
qc_staticLimits is an indicator that the chart has user-set limits
qc_WarningsTested is a list of warnings that were tested
qc_test1N is the customized n value for Test 1
qc_test1Label is the customized label for Test 1
qc_test2N is the customized n value for Test 2
qc_test2Label is the customized label for Test 2
qc_test3N is the customized n value for Test 3
qc_test3Label is the customized label for Test 3
qc_test4N is the customized n value for Test 4
qc_test4Label is the customized label for Test 4
qc_test5N is the customized n value for Test 5
qc_test5M is the customized m value for Test 5
qc_test5Label is the customized label for Test 5
qc_test6N is the customized n value for Test 6
qc_test6M is the customized m value for Test 6
qc_test6Label is the customized label for Test 6
qc_test7N is the customized n value for Test 7
qc_test7Label is the customized label for Test 7
qc_test8N is the customized n value for Test 8
qc_test8Label is the customized label for Test 8
Example 1: Automatically Writing to a Log
One way to generate automatic alarms is to make a script and store it with the data table as a data table script or column property named QC Alarm Script.
The following example automatically writes a message to the log whenever a test fails:
dt = Open( "$SAMPLE_DATA/Quality Control/Coating.jmp" );
	Variables( Y( :Weight ), Subgroup( :Sample ) ),
	Show Control Panel( 0 ),
	Show Limit Labels( 1 ),
		Alarm Script(
		Write(
			"Out of Control for test ",
			qc_test,
			" in column ",
			qc_col,
			" in sample ",
			qc_sample
obj << Chart( Position( 1 ), Warnings( Test 1( 1 ) ) );
Example 2: Running a Chart with Spoken Tests
You can create a control chart with tests that are spoken aloud using the Speak function. Try the following example:
	Alarm Script(
		Speak(
			Match( QC_Test,
				1, "One point beyond Zone A",
				QC_Test, 2,
				"Nine points in a row in zone C or beyond", QC_Test,
				5,
					"Two out of three points in a row in Zone A
					or beyond"
	Chart(
		Position( 1 ),
		Warnings( Test 1( 1 ), Test 2( 1 ), Test 5( 1 ) )
You can have either of these scripts use any of the JSL alert commands, such as Speak, Write, or Mail.
Set Phase Limits
A phase is a group of consecutive observations in the data table. For example, phases might correspond to time periods during which a new process is brought into production and then put through successive changes. Phases generate, for each level of the specified Phase variable, a new sigma, set of limits, zones, and resulting tests.
The following example illustrates setting the limits for the different phases of Diameter.jmp:
New Table( "Phase Limits",
	Add Rows( 8 ),
	New Column( "_LimitsKey", Character, Nominal,
		Set Values( {"_Sigma", "_Mean", "_LCL", "_UCL", "_Sigma", "_Mean", "_LCL", "_UCL"} )
	New Column( "Phase", Character, Nominal,
		Set Values( {"1", "1", "1", "1", "2", "2", "2", "2"} )
	New Column( "DIAMETER", Continuous,
		Set Values( [0.29, 4.3, 3.99, 4.72, 0.21, 4.29, 4, 4.5] )
	Variables( Y( :DIAMETER ), Subgroup( :DAY ), Phase( :Phase ) ),
