发布日期: 09/15/2026
Installing Multiple Add-Ins
If you want to install multiple add-ins, copy the add-ins into the following location:
• Add-In files on Windows are located here:
– %ALLUSERSPROFILE%\JMP\JMP\AddIns (any user on this machine can access the add-in)
– %APPDATA%\JMP\JMP\AddIns (only the current user on this machine can access the add-in)
• Add-In files on Apple macOS are located here:
– /Library/Application Support/JMP/AddIns (any user on this machine can access the add-in)
– ~/Library/Application Support/JMP/AddIns (only the current user on this machine can access the add-in)
When JMP starts, the addinRegistry.xml file is read, which contains information about previously registered JMP add-ins. Then JMP looks in the add-in folders for any other add-ins and installs them automatically.
Notes:
• The Home Folder for discovered add-ins does not have to be the AddIns subfolder in which the addin.def file was found. The addin.def file can be the only file in that subfolder and have a Home setting that points to some other location where the add-in files actually reside.
• If an automatically discovered add-in has the same unique ID as an add-in that was explicitly registered, the automatically discovered add-in is used.
