发布日期: 09/15/2026
R Integration Functions
R Connect( <named_arguments> )
Description
Returns the current R connection object. If there is no connection to R, it intializes the R integration interface and returns an active R integration interface connection as a scriptable object.
Returns
R scriptable object.
Arguments
Echo(Boolean)
(Optional) Sends all source lines to the JMP log. This option is global. The default value is true.
R Control( Echo(Boolean) )
Description
Changes the control options for R. As of JMP 19, the Interrupt and Async options have no effect, and are no longer listed as possible arguments.
Argument
Echo(Boolean)
Whether to send source lines to the JMP log. Optional.
R Execute( { list of inputs }, { list of outputs }, "rCode" )
Description
Submits the specified R code to the active global R connection given a list of inputs. On completion, the output list is populated.
Returns
0 if successful; nonzero otherwise.
Arguments
{ list of inputs }
A list of JMP variables or named columns to be sent to R as inputs.
{ list of outputs }
A list of JMP variable names to contain the outputs returned from R.
rCode
A quoted string that contains the R code to submit.
Examples
Send the JMP variables x and y to R, execute the R statement z <- x + y, and then get the R variable z and return it to JMP.
x = [1 2 3];
y = [4 5 6];
rc = R Execute( {x, y}, {z}, "z <- x + y" );
jz = R Get( z );
jz;
Send multiple named columns
R Execute( { dt:age, dt:height, dt:weight }, {}, “R code here” );
R Get( variable_name )
Description
Gets the named variable from R. The variable can represent any of the following data types: numeric, string, matrix, list, data frame.
Returns
The value of the named variable.
Argument
variable_name
Required. The name of an R variable whose value to return to JMP.
Example
Assume that a matrix named qbx and a data frame named df are present in your R connection.
// get the R variable qbx and placed it into a JMP variable qbx.
qbx = R Get( qbx );
// get the R variable df and placed it into a JMP data table
// referenced by df.
df = R Get( df );
R Get Graphics( "format" )
Description
Deprecated in JMP 19 and has no effect.
Details
As an alternative, set the graphics device to a filename such as png("r_plot.png"), plot to a file, and then open the file to get the image.
Names Default To Here( 1 );
R Init();
img_path = Get Path Variable( "TEMP" ) || "r_plot.png";
R Execute( {img_path}, {}, "\[
png(img_path)
plot(1:10)
dev.off()
plot = Open( img_path );
rc = Delete File( img_path );
R Get Version()
Description
Returns the version number of R being used with the JMP R interfaces.
R Init( named_arguments )
Description
Initializes the R session.
Returns
0 if the initialization is successful; any nonzero value otherwise.
Argument
Echo(Boolean)
R Is Connected()
Description
Determines whether a connection to R exists.
Returns
1 if connected; 0 otherwise.
R JMP Name to R Name( JMP_variable_name )
Description
Maps the specified JMP variable name to the corresponding R variable name using R naming rules. Requires an active connection to R.
Returns
A quoted string that contains the R name.
Argument
JMP_variable_name
The name of a JMP variable to be sent to R.
R Send( name, <R Name( as_name ) | "as_name">)
Description
Sends named variables from JMP to R. The variable can represent any of the following data types: numeric, string, matrix, list, data table, data table column, data frame.
Returns
0 if the send is successful; any nonzero value otherwise.
Arguments
name
Required. The name of a JMP variable to be sent to R.
R Name(as_name)
(Optional) A different name for the variable in R.
as_name
(Optional) The name assigned to the variable in the R environment. The name is automatically passed through R Name() to ensure a valid R variable name.
Details
For data tables only:
Selected(Boolean)
optional, named, Boolean. Send only selected rows from the referenced data table to R.
Excluded(Boolean)
optional, named, Boolean. Send only excluded rows from the referenced data table to R.
Labeled(Boolean)
optional, named, Boolean. Send only labeled rows from the referenced data table to R.
Hidden(Boolean)
optional, named, Boolean. Send only hidden rows from the referenced data table to R.
Colored(Boolean)
optional, named, Boolean. Send only colored rows from the referenced data table to R.
Markered(Boolean)
optional, named, Boolean. Send only markered rows from the referenced data table to R.
Row States(Boolean, <named arguments>)
optional, named. Includes a Boolean argument and optional named arguments. Send row state information from the referenced data table to R by adding an additional data column named “RowState”. Multiple row states are created by adding together individual settings. Here are the individual values:
– Selected = 1
– Excluded = 2
– Hidden = 4
– Labeled = 8
– Colored = 16
– Markered = 32
Here are the named arguments for the Row States() argument:
Colors(Boolean)
optional, named, Boolean. Sends row colors. Adds additional data column named “RowStateColor”.
Markers(Boolean)
optional, named, Boolean. Sends row markers. Adds additional data column named “RowStateMarker”.
Examples
Assuming variable dt is ‘Big Class.jmp’, create an R Vector named ‘weight’ with the values from the weight column:
R Send( dt:weight );
Create a matrix, assign it to X, and send the matrix to R:
X = [1 2 3];
rc = R Send( X );
Open a data table, assign a reference to it (dt), and send the data table, along with its current row states, to R:
rc = R Send( dt, Row States(1) );
R Send File( "filename", <R Name("name")>)
Description
Sends the specified file from JMP to R.
Returns
Arguments
filename
Required. A quoted string that contains a path for a file.
R Name(name)
(Optional) The name assigned to the file in the R environment.
R Submit( "rCode", <named_arguments> )
Description
Submits the specified R code to the active global R connection.
Returns
Arguments
rCode
A required, quoted string that contains the R code to submit.
Expand(Boolean)
An optional named argument. Performs an Eval Insert() on the R code before submitting to R.
Echo(Boolean)
An optional named argument. Sends all source lines to the JMP log. This option is global. The default value is true.
Async(Boolean)
An optional named argument. If set to true (1), the submit can be canceled either by pressing the ESCAPE key, or by using this message to an R connection: rconn<<Control( Interrupt( 1 ) ). False (0) is the default value.
Example
rc = R Submit("\[
	x <- rnorm(5)
	print(x)
	y <- rnorm(5)
	print(y)
	z = plot(x, y)
R Submit File( "pathname" )
Description
Submits statements to R using a file.
Returns
Argument
pathname
A quoted string that contains the pathname of the file that contains the R code to execute.
