Select Graph > Scatterplot 3D.
Click OK.
From the red triangle menu, select Normal Contour Ellipsoids. Notice that Ungrouped is already selected.
8.
Click OK.
Click OK.
6.
Select Grouped by Column.
7.
Select Species.
10.
Click OK.
Click OK.
From the red triangle menu, select Nonpar Density Contour.
6.
7.
Select Species and click OK. A different colored contour is displayed for each of the three species.
The options for formatting the grouped and ungrouped nonparametric density contours are similar. The only difference is that you cannot change the color of each grouped nonparametric density contour. See Descriptions of the Scatterplot 3D Options for options.
