Design of Experiments Guide covers classic DOE designs (for example, full factorial, response surface, and mixture designs). Read about more flexible custom designs, which you generate to fit your particular experimental situation. Discover JMP’s definitive screening designs, an efficient way to identify important factor interactions using fewer runs than required by traditional designs. And read about creating designs that test systems where failures occur as a result of interactions among components or subsystems. The book also provides guidance on determining an appropriate sample size for your study.
