JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
• Space-Filling Designs
Space-Filling
Designs
Space-filling designs are useful in situations where run-to-run variability is of far less concern than the form of the model. Consider a sensitivity study of a computer simulation model. In this situation, and for any mechanistic or deterministic modeling problem, any variability is small enough to be ignored. For systems with no variability, replication, randomization, and blocking are irrelevant.
The Space Filling platform provides designs for situations with both continuous and categorical factors. For continuous factors, space-filling designs have two objectives:
maximize the distance between any two design points
space the points uniformly
Contents
Overview of Space-Filling Designs
Space Filling Design Window
Responses
Factors
Define Factor Constraints
Space Filling Design Methods
Design
Design Diagnostics
Design Table
Space Filling Design Options
Sphere-Packing Designs
Creating a Sphere-Packing Design
Visualizing the Sphere-Packing Design
Latin Hypercube Designs
Creating a Latin Hypercube Design
Visualizing the Latin Hypercube Design
Uniform Designs
Comparing Sphere-Packing, Latin Hypercube, and Uniform Methods
Minimum Potential Designs
Maximum Entropy Designs
Gaussian Process IMSE Optimal Designs
Fast Flexible Filling Designs
FFF Optimality Criterion
Set Average Cluster Size
Constraints
Creating and Viewing a Constrained Fast Flexible Filling Design
Borehole Model: A Sphere-Packing Example
Create the Sphere-Packing Design for the Borehole Data
Guidelines for the Analysis of Deterministic Data
