Minimum Potential Design
Select DOE > Space Filling Design.
Click Continue.
6.
Click the Minimum Potential button. JMP creates this design and displays the design runs and the design diagnostics (shown on the right in Space-Filling Methods and Design Diagnostics for Minimum Potential Design).
7.
Click Make Table.
In the Scatterplot 3D launch dialog, select X1, X2, and X3 as Y, Columns and click OK to see the initial three dimensional scatterplot of the design points.
To see the results similar to those in Minimum Potential Design Points on Sphere, select the Normal Contour Ellipsoids option from the menu in the Scatterplot 3D title bar, and make the points larger by right-clicking on the plot and selecting Settings, then increasing the Marker Size slider.
