Treemaps can be useful in cases where histograms or bar charts are ineffective. This example uses the Cities.jmp sample data table, which contains meteorological and demographic statistics for 52 cities. Compare the bar chart to the treemap.
Select Graph > Chart.
Select Mean.
Click OK.
Return to the Cities.jmp sample data table.
Select Graph > Treemap.
Click OK.
