This example uses the Dogs.jmp sample data table, which contains histamine level measurements for 16 dogs that were given two different drugs. The histamine levels were taken at zero, one, three, and five minutes. Examine the variation in the histamine levels for each drug.
Open the Dogs.jmp sample data table.
Select Rows > Color or Mark by Column.
Select drug and click OK.
Select Graph > Parallel Plot.
Select hist0, hist1, hist3, and hist5 and click Y, Response.
6.
Parallel Plot of Histamine Variables
7.
Select Rows > Data Filter.
8.
Select drug and click Add.
Trimeth Values Highlighted
From Trimeth Values Highlighted, you observe the following about the histamine levels for dogs given trimeth:
