Extract Values from Reports.jsl (Script for Extracting Values into a Custom Report (Part 1) and Script for Extracting Values into a Custom Report (Part 2)) and performs a Bivariate analysis and shows results such as the sample size, RSquare, and Correlation in a new report window. Customized Report from the Bivariate Analysis shows the Bivariate report along with the customized report, though the Bivariate report window closes after the script is finished.
