JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Specialized Models
Partition Models
• Fit Group
Fit Group
For all but the K Nearest Neighbors method, when more than one Y is entered as Y, Response, a report is provided for each response. These individual reports appear in a Fit Group report. The Fit Group report’s red triangle menu provides three options:
Arrange in Rows
Arranges the reports for the individual responses horizontally. In the text box, enter the number of reports that you want to see displayed in each row.
Order by Goodness of Fit
Sorts the individual response reports in order of decreasing RSquare or Entropy RSquare values. If a validation portion (or, in JMP Pro, a validation column) is specified, the reports are ordered based on the RSquare or Entropy RSquare values for the training set.
Note that for a nominal response, the RSquare is also referred to as the Entropy RSquare.
Script
Contains options that are available to all platforms. See
Using JMP
