Use the Knotted Spline Effect option to have JMP fit a segmentation of smooth polynomials to a specified effect. When you select this attribute, a window appears, enabling you to specify the number of knot points. (Knotted splines are only implemented for main-effect continuous terms.)
Knotted splines are parsimonious, adding only k – 2 terms for curvature for k knot points.
Select Help > Sample Data Library and open Growth.jmp.
Select Analyze > Fit Model.
Fit Model Launch Window
Select the ratio column and click Y.
Select the age column and click Add.
Select age in the Effects pane and select Attributes > Knotted Spline Effect.
7.
Click Run.
9.
Click the Add Column button twice to produce a total of three columns.
10.
11.
Values for the Custom Test for Curvature
13.
Click Done.
The report in Curvature Report appears. The small Prob > F value indicates that there is curvature.
Curvature Report
