JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Basic Analysis
Matched Pairs Analysis
• Launch the Matched Pairs Platform
Launch the Matched Pairs platform by selecting
Analyze > Matched Pairs
The Matched Pairs Launch Window
Description of the Matched Pairs Launch Window
Y, Paired Response
Provide the two response columns. For information about analyzing more than two responses, see
Multiple Y Columns
X, Grouping
(Optional) Provide a grouping variable to compare the differences across groups. For more information, see
Across Groups
Weight
(Optional) Identifies one column whose numeric values assign a weight to each row in the analysis.
Freq
(Optional) Identifies one column whose numeric values assign a frequency to each row in the analysis.
By
(Optional) Performs a separate matched pairs analysis for each level of the By variable.
For more information about the launch window, see
Using JMP
After you click
OK
, the Matched Pairs report window appears. See
The Matched Pairs Report
Multiple Y Columns
You can have more than two responses. If the number of responses is odd, all possible pairs are analyzed. The following table shows an example for three responses.
Y1 by Y2
Y1 by Y3
Y2 by Y3
If the number of responses is even, the Matched Pairs platform asks whether you want to do all possible pairs. If you do not do all possible pairs, adjacent responses are analyzed as a pair. The following table shows the arrangement of analyses for four responses.
Y1 by Y2
Y3 by Y4
