For mixture designs, a Lock column appears in the Contour Profiler (Boxes to Lock Columns). This column enables you to lock settings for mixture values so that they are not changed when the mixture needs to be adjusted due to other mixture effects being changed. When locked columns exist, the shaded area for a mixture recognizes the newly restricted area.
