Beneath the graph are the control buttons: Split, Prune, and Go. The Go button only appears if there is a validation set. Also shown is the name of the Treatment column and its two levels, called Treatment1 and Treatment2. If more than two levels are specified for the Treatment column, all but the first level are treated as a single level and combined into Treatment2.
The decision tree shows the splits used to model uplift. See Nodes for First Split for an example using the Hair Care sample data table. Each node contains the following information:
The t ratio for the test for a difference in response across the levels of Treatment for subjects in this node. If the response is categorical, it is treated as continuous (values 0 and 1) for this test.
When the response is continuous, this is the coefficient of the interaction term in the linear regression model used in computing the F ratio. When the response is categorical, this is an estimate of the interaction constructed from Firth-adjusted log-odds ratios.
See Uplift Graph for an example of an Uplift Graph for the Hair Care sample data table after three splits. Note that, for two groups of subjects (males and non-blond women in the Age  42 group), the promotion has a negative effect.
Uplift Graph
