The t Distribution
What is the t distribution?
The t distribution describes the standardized distances of sample means to the population mean when the population standard deviation is not known, and the observations come from a normally distributed population.
Is the t distribution the same as the Student’s t distribution?
Yes.
What’s the key difference between the t and z distributions?
The standard normal or z distribution assumes that you know the population standard deviation. The t distribution is based on the sample standard deviation.
t distribution vs. normal distribution
The t distribution is similar to a normal distribution. It has a precise mathematical definition. Instead of diving into complex math, let’s look at the useful properties of the t distribution and why it is important in analyses.
Consider the following graph comparing three t distributions with a standard normal distribution:
Figure 1: Three t distributions and a standard normal (z) distribution.
All of the distributions have a smooth shape. All are symmetric. All have a mean of zero.
The shape of the t distribution depends on the degrees of freedom. The curves with more degrees of freedom are taller and have thinner tails. All three t distributions have “heavier tails” than the z distribution.
You can see how the curves with more degrees of freedom are more like a z distribution. Compare the pink curve with one degree of freedom to the green curve for the z distribution. The t distribution with one degree of freedom is shorter and has thicker tails than the z distribution. Then compare the blue curve with 10 degrees of freedom to the green curve for the z distribution. These two distributions are very similar.
A common rule of thumb is that for a sample size of at least 30, one can use the z distribution in place of a t distribution. Figure 2 below shows a t distribution with 30 degrees of freedom and a z distribution. The figure uses a dotted-line green curve for z, so that you can see both curves. This similarity is one reason why a z distribution is used in statistical methods in place of a t distribution when sample sizes are sufficiently large.
Figure 2: z distribution and t distribution with 30 degrees of freedom
Tails for hypothesis tests and the $t$ distribution
When you perform a t-test, you check if your test statistic is a more extreme value than expected from the t distribution.
For a two-tailed test, you look at both tails of the distribution. Figure 3 below shows the decision process for a two-tailed test. The curve is a t distribution with 21 degrees of freedom. The value from the t distribution with α = 0.05/2 = 0.025 is 2.080. For a two-tailed test, you reject the null hypothesis if the test statistic is larger than the absolute value of the reference value. If the test statistic value is either in the lower tail or in the upper tail, you reject the null hypothesis. If the test statistic is within the two reference lines, then you fail to reject the null hypothesis.
Figure 3: Decision process for a two-tailed test
For a one-tailed test, you look at only one tail of the distribution. For example, Figure 4 below shows the decision process for a one-tailed test. The curve is again a t distribution with 21 degrees of freedom. For a one-tailed test, the value from the t distribution with α = 0.05 is 1.721. You reject the null hypothesis if the test statistic is larger than the reference value. If the test statistic is below the reference line, then you fail to reject the null hypothesis.
Figure 4: Decision process for a one-tailed test
How to use a $t$ table
Most people use software to perform the calculations needed for t-tests. But many statistics books still show t tables, so understanding how to use a table might be helpful. The steps below describe how to use a typical t table.
  1. Identify if the table is for two-tailed or one-tailed tests. Then, decide if you have a one-tailed or a two-tailed test. The columns for a t table identify different alpha levels.
    If you have a table for a one-tailed test, you can still use it for a two-tailed test. If you set α = 0.05 for your two-tailed test and have only a one-tailed table, then use the column for α = 0.025.
  2. Identify the degrees of freedom for your data. The rows of a t table correspond to different degrees of freedom. Most tables go up to 30 degrees of freedom and then stop. The tables assume people will use a z distribution for larger sample sizes.
  3. Find the cell in the table at the intersection of your α level and degrees of freedom. This is the t distribution value. Compare your statistic to the t distribution value and make the appropriate conclusion.
