Perform Double FDR Adjustment
Check this option to conduct the Double FDR methodology of Mehrotra and Adewale (2011).
To perform this method in Adverse Events Risk Report and other reports, you must select either Preferred Term or Verbatim Term as the Term Level and you must also select a Group Level.
Note: The Double FDR method uses the specified Multiple Testing Method.
