-log10(p-Value) Cutoff
This parameter is used to specify a cutoff for -log10(p-values) in order to select significant hypothesis tests. This parameter is used when no multiple testing method is specified.
If you do not specify LSMeans differences or ESTIMATE statements, the selection is made across Type 3 tests of the fixed effects.
To Specify a -log10(p-Value) Cutoff Value:
| 8 | Select the blank space in the Multiple Testing Method drop-down menu to enable the -log10(p-Value) Cutoff field. |
| 8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
