Multiple Testing Method
This drop-down menu enables you to adjust your model for multiple hypothesis tests across all Means or LSMeans differences.
Note: If you do not specify Means or LSMeans differences, p-value adjustments are made across the Type 3 tests for all of the fixed effects and covariates.
The AdaptiveHolm, AdaptiveHochberg, Bonferroni, Holm, Hommel, Sidak, StepBon, and StepSid methods all control for the familywise error rate. The methods based on FDR all control for false discovery rate.
Multiple Testing Method |
Definition |
None |
AdaptiveHolm |
AdaptiveHochberg |
Bonferroni |
Note: These adjustments can be extremely conservative and should be viewed with caution. |
Hochberg |
Hommel |
Holm |
Sidak |
Note: These adjustments are slightly less conservative than the Bonferroni adjustments, but they still should be viewed with caution. |
StepBon |
StepSid |
AdaptiveFDR |
Dependent FDR |
FDR |
pFDR |
To Specify a Multiple Testing Method:
| 8 | Make a selection using the drop-down menu. |
Refer to p-Value Adjustments for more details about each of these methods.
