Findings Time Trends
The Findings Time Trends report enables findings data, typically laboratory test results, to be summarized over time by treatment group. Time is typically defined by both visits and time points. By default, laboratory test results are summarized using the mean change from baseline and corresponding 95% confidence intervals, allowing reviewers to assess whether mean post-baseline values are trending upward or downward across visits. Alternative summary measures include percent change from baseline, percent of baseline, and observed results. For observed results, upper and lower limits of normal (ULN and LLN) cutoff lines are displayed for the individual tests. The report first displays a line graph showing the mean values of each treatment group. A bar graph below the line graph displays the number of records contributing to the baseline and post-baseline calculations. Finally, individual subject profiles are displayed as line graphs, showingeach subject's laboratory results over time and enabling investigators to evaluate each data point for every subject on the trial.
Methodology
No testing is performed. The analysis is limited to the calculation of simple statistics for post-baseline findings results, or their log-transformed and/or normalized values, relative to baseline values.
If findings test category (xxCAT) exists (where xx represents the two-letter domain abbreviation, for example, LB), plots are first ordered by xxCAT. If findings test subcategory (xxSCAT) exists, plots are then ordered by xxSCAT within xxCAT. If xxCAT is missing, plots are ordered by test short name (xxTESTCD), which is required. Findings tests with a missing xxCAT value are assigned to the “OTHER” category.
Note: Findings tests with a missing numeric result (xxSTRESN), as well as those collected on only one day, are excluded from these plots.
Tip: You can collapse categories, and simultaneously exclude them from any report that you create, by clicking the gray triangles located to the left of the category labels.
Each plot displays measurements collected over time for each subject in the study for a quantitative findings test. The value of xxTEST is displayed in the outline box for each plot, and the test short name (xxTESTCD) is displayed along with the measurement units (when applicable) on the Y-axis. The Y-axis can represent the observed test result, change from baseline, percent change from baseline, or percent of baseline, depending on the selection made for the Plot findings measurements as: parameter in the report dialog. Time, represented as either Study Day, Study Week, or Visit, (according to yourTime Scale selection), is plotted on the X-axis . Time trend lines connect measurement points, with each marker point representing a findings measurement for a subject at a specific time point. If multiple measurements were collected for a subject on the same Study Day, Study Week, or Visit, the plotted point represents the mean measurement for that subject.
Usage and Interpretation
The Findings Time Trends report was run using the Nicardipine sample data set under several scenarios to demonstrate the usage and interpretation of the results.
Note: Click on the figures below to enlarge.
Example 1: Mean Change from Baseline in BUN Over Time by Treatment
Example 2. Mean Observed Result for Bilirubin (mMol/L) over Time by Treatment
Options
Data
Treatment or Comparison Variable
Domain
Findings Tests
Show all Findings Tests
By Variables
Remove unscheduled visits
Include missing visits/time points
Calculate baseline as:
Snapshot Records to Include
Additional Filters - Findings
Display
Test Results/Vital Signs
Action Buttons
Action buttons provide you with an easy way to drill down into your data. The following action buttons are generated by this report:
Default Settings
