Findings Waterfall Plots
This report creates waterfall plots to show the distribution of changes in test measurements for a given Findings domain across subjects (ordered by their magnitude of change). The Findings measurements are summarized based on a specified summary statistic and a waterfall plot is created for each Findings test.
Note: JMP Clinical uses a special protocol for data including non-unique Findings test names. Refer to How does JMP Clinical handle non-unique Findings test names? for more information.
Methodology
Counts of subjects with findings results are tabulated for each visit. Mean, median, standard deviation, minimum and maximum values are computed for selected findings test for each visit.
Usage and Interpretation
Example 1:
Running Findings Waterfall Plots with the Nicardipine sample setting and LB findings domain generates the report shown below.
Waterfall Plots
There is one Waterfall Plot for each quantitative findings test (for example, laboratory tests) in the Findings data set that was analyzed. Output data set is a stacked data set of findings measurements at subject level; subject level drill downs available.
Use the filter at left to select the finding plot to view. Each plot shows a summary of the findings test measurements on the Y axis for each subject (on X axis) ordered by that measurement. Caption boxes in the upper right corner of each graph (optional) display a summary statistic across all subjects (in a treatment or BY variable group) to aid in understanding the differences in the center/spread of the group distributions.
Options
Data
Treatment or Comparison Variable
Specifies the variable used to define the groups to be compared in the report. This variable is typically a planned or actual treatment variable, such as ARM, ACTARM, TRTxxA, or TRTxxP, but it can also be another variable that defines meaningful comparison groups, such as SEX or RACE.
Select None to display the data without grouping by a treatment or comparison variable.
Domain
Use this widget to specify whether to analyze measurements from either the Electrocardiogram (EG), Laboratory (LB), or Vital Signs (VS) findings domains.
LB is selected by default.
Findings Tests
Use this widget to select specific Findings tests. If you leave this field blank, all tests are run.
| 8 | Click to open the Add window (shown below) that lists available test names (shown below). |
| 8 | Select the desired test(s) and click to add them to the text box. |
Subset of Visits to Analyze
Use this option to select the visits to be analyzed.
Note: Visits are selected from the Findings domain specified by the Domain widget only.
To Specify a Subset of Visits:
| 8 | Click to open the Add window that lists available visits (shown below). |
| 8 | Select the visits you want to include in the analysis and click to add those visits to the text box. |
In this example, visits 1,5,6, and 9 were selected and added.
By Variables
Use this field to specify one or more By variables from ADSL to use in your analysis.
Selecting a By variable will split the bar chart and tabulate by the grouping variables selected in this option as well as by the variable selected for the comparison or treatment variable.
By Variables
By variables are optional (in most reports)variable specifications whose values define groups of observations, such as hour, month, or year. By variables can enable analyses to be performed separately on different groups as defined by that variable. Choosing a By variable such as gender (ADSL variable = SEX), for example, groups the subjects by gender and conducts two separate analyses: one for males and one for females.
Alternatively, specifying a By variable enables you to animate an image so that you can see how response values change according to some grouping, like over time.
To Specify One or More By Variables:
| 8 | Click to open the Add window (shown below) that lists each variable contained in domain and SUPPxx (if merged) specific to this report |
Note: In Demographics Distribution only, variables are taken from ADSL, in addition to the report-specific DS and SUPPPDS (if available) data sets.
| 8 | Select the variables you want to include in the analysis and click to add those variables to the text box. |
In this example, AGE Group 1, RACE, and SEX were selected and added.
Note: If no By variables are specified, the analysis is conducted across all the subjects
Plot findings measurements as:
Use this widget to specify whether to plot the results either as observed or how they relate to the baseline measurement.
Available options are listed in the following table:
Option |
Description |
Observed result |
Plots observed values of the xxSTRESNvariable at or within time points or specified time periods. |
Change from baseline |
Plots the change from the findings baseline measurements. |
Percent change from baseline |
Plots 100*((xxSTRESN - Baseline)/Baseline) across trial time points. |
Percent of baseline |
Plots 100*(xxSTRESN/Baseline). |
Summary Statistic for Trial Data
Use the drop-down to specify whether to display the mean (specified by default), median, maximum, minimum, or last values to summarize the results of the trial period.
Options are defined in the following table:
Summary Statistic |
Definition |
Min |
Mean |
Median |
Max |
Last |
Remove unscheduled visits
You might want to include unscheduled visits when you are analyzing findings by visit.
By default, this box is checked. When it is checked, records are excluded from the analysis if the VISIT variable exists and contains the text "unscheduled" for those records. If the box is not checked, all records are included regardless of the VISIT status.
For some reports, you might have to specify Visits as the Time Scale to enable this field.
Calculate baseline as:
Use this widget to use the flagged baseline record, last recorded pre-dose measurement, or the mean of all the measurements taken during the baseline time window as the baseline measurement.
By default, the flagged baseline record is used.
The following test measurements are considered when forming the baseline measurement:
| • | Those flagged as baseline |
| • | Those taken prior to Study Day 1 |
Choose Last recorded pre-dose measurement to use the last recorded predose test measurement (out of the test measurement pool generated from the above list) as the baseline measurement.
Choose Mean of recorded pre-dose measurements to average these predose test measurements to form the baseline measurement.
Note: When the selected option to calculate baseline is to use the baseline flag and there are two records flagged as baseline, JMP Clinical uses the last record. This differs from JMP Clinical version 8.1, where the mean of the flagged baseline values was used.
Snapshot Records to Include
Use this widget to specify which updated snapshot records to include in your analysis. This option is surfaced only in studies where the number of snapshots is greater than 0.
The default state of this option is to show new, modified, and stable - effectively all - snapshot records. To see specific records, you must remove undesired records from the analysis. For example, to surface only the new records, select both Modified and Stable and click
. Click
to restore deleted records.
Note: JMP Clinical now relies on the JMP Compare Data Tables platform to detect new records. When duplicate rows appear, the platform evaluates them based on their row order. As a result, records are no longer labeled as Non‑Unique or Previously Non‑Unique, and the corresponding options to include those records have been removed.
Additional Filters - Findings
This filter lets you restrict your analysis to only those subjects that meet specific criteria at the level of the specified Findings domain (EG, LB, or VS) .
This filters uses JMP WHERE clauses to Select Rows that meet the specified criteria. To use this filter, you must enter the JSL (JMP Scripting Language) expressions that constitute the WHERE clause in the appropriate text box for specific filtering of findings. Note: This is an advanced concept that not only requires some basic knowledge of the JSL WHERE clause syntax (similar to, but different from, SQL), but also an understanding of the exact variables in the tables in the study.
Risk indicators are calculated using this subset only.
To specify a Findings filter:
| 8 | Click to open the WHERE Clause Builder to construct the desired filter. |
| 8 | Click to clear the filter. |
Note: To filter subjects with a specific event or finding, one could also use the Subpopulation Builder on any domain of interest. For example, filter to all subjects that exhibit cardiac failure ( :Customized Query 01 Name == "Cardiac failure" ) and run all reports on those.
Display
Test Results/Vital Signs
This option lists all of the tests performed over the course of the study. The list is specific to the selected Findings domain and changes when you change the selected domain.
| 8 | Select one or more tests to display only the results for the selected domains. |
Action Buttons
Action buttons provide you with an easy way to drill down into your data. The following action buttons are generated by this report:
| • | Click to rerun the report using default settings. |
| • | Click to view the associated data tables. Refer to Show Tables for more information. |
| • | Click to generate a standardized PDF- or RTF-formatted report that contains the plots and charts of selected sections. |
| • | Click to generate a JMP Live report. Refer to Create Live Report for more information. |
| • | Click to take notes and store them in a central location. Refer to Add Notes for more information. |
| • | Select one or more subjects and then click to apply the Review Subject Filter and filter all reports in the review builder on the selected subjects. |
| • | Select a group of subjects and click to specify Derived Population Flags that enable you to distinguish the selected group of subjects from the general population. |
Default Settings
Methodology
No testing is performed. Analysis is restricted to calculating simple statistics of findings results.
to open the
to open the
to open the
to apply the
to specify
