Number of decimals to display for event percentages in tables
Specify the number of decimal places for reporting calculated event percent occurrence (%) for the treatment emergent static report (in PDF or RTF format).
Note: The subject occurrence count, N, does not use decimals.
To Specify the Number of Decimal Places to Display for Event Percentages:
| 8 | Either enter the desired value in the text field or move the slider to the right or to the left to change the value. |
Tip: To change the scale of the slider, right-click on the slider and select from the pop-up menu. Change the upper or lower boundaries in the that appears, to rescale the slider and click .
Note: For information about how treatment emergent adverse events (TEAEs) are defined in JMP Clinical, please refer to How does JMP Clinical determine whether an Event Is a Treatment Emergent Adverse Event?.
