Select a platform from the Analyze, Graph, or DOE menus. Platforms contain interactive windows that you use to analyze data and work with graphs.
Launch windows where you set up and run your analysis.
Report windows showing the output of your analysis.
Specific reports that you can show or hide using the disclosure button .
Platform options that are located within red triangle menus .
Help created on 9/19/2017
