The Work with Your Data topic shows you how to get data into JMP.
The Visualize Your Data topic shows you how to use some of the useful graphs JMP provides to look more closely at your data.
The Analyze Your Data topic shows you how to use some of the analysis platforms.
The The Big Picture topic shows you how to analyze distributions, patterns, and similar values in several platforms.
