This example shows how to combine two reports from Hollywood Movies.jmp into a dashboard.
Select Window > Combine Windows.
In the Filter By column, select Hollywood Movies - Distribution.
Click OK.
In the Combine Windows window, select Summary Report View to see only the graphs in a report and omit the statistics.
