For each Y variable, saves a column to the data table called Pred Formula <response> that contains its the prediction formula.
For each Y variable, saves a column to the data table called Pred Formula <response> that contains the prediction formula in terms of the X scores.
For each Y variable, saves a column to the data table called PredSE <response> that contains the standard error of the predicted mean. For details, see Standard Error of Prediction and Confidence Limits.
For each Y variable, saves two columns to the data table called Lower 95% Mean <response> and Upper 95% Mean <response>. These columns contain 95% confidence limits for the response mean. For details, see Standard Error of Prediction and Confidence Limits.
For each Y variable, saves two columns to the data table called Lower 95% Indiv <response> and Upper 95% Indiv <response>. These columns contain 95% prediction limits for individual values. For details, see Standard Error of Prediction and Confidence Limits.
Columns called X Score <N> Formula containing the formulas for each X Score.
Columns called Y Score <N> Formula containing the formulas for each Y Score
Saves the T2 values to the data table. These are the values used in the T Square Plot.
Saves the Distance to X Model (DModX) and Distance to Y Model (DModY) values to the data table. These are the values used in the Distance Plots.
Help created on 9/19/2017
