Consider first the case of a single parameter, θ. Let l be the log-likelihood function for θ and let x be the data. The score is the derivative of the log-likelihood function with respect to θ:
The score test can be generalized to multiple parameters. Consider the vector of parameters θ. Then the test statistic for the score test of H0:
is:
is:The test statistic is asymptotically Chi-square distribution with k degrees of freedom. Here k is the number of unbounded parameters.
Let
be the value of
where the algorithm terminates. Note that the relative gradient evaluated at
is the score test statistic. A p-value is calculated using a Chi-square distribution with k degrees of freedom. This p-value gives an indication of whether the value of the unknown MLE is consistent with
. The number of unbounded parameters listed in the Random Effects Covariance Parameter Estimates report equals k.
be the value of
Statistical Details
Convergence Score Test
is:
denotes the transpose of the matrix
. Here,
is the gradient of the log-likelihood function and
is its Hessian.
